View Full Version : CF 3102 ATDC sensor location?
kanini
04-04-2008, 11:30 PM
Hi everyone! Great forum for a "newbie"! Just a silly question: where is the ATDC sensor located on a Konica Minolta CF3102? :o
It seems as I have to check and clean it, I get "near trouble P-5" error, and the gradiation print won't work anymore (says "Stabilizer NG" in tech rep. mode, even after I've stabilized it). I get dark backgrounds on my copies. Any suggestions would be very much appreciated! THANKS!
Best regards from Finland
nmfaxman
04-05-2008, 06:56 AM
What color is the background?
It is either a drum ground or a bias loss.
kanini
04-05-2008, 08:23 AM
Hi! The background is a bit foggy with black toner (or actually it's all over the paper including where color is printed), when looking close it's like it's got black toner "dust" or small dots all over the paper, like when trying to copy and you've got too dark setting. I'm printing some files (so nothing to do with the settings), and the black "dust" has always disappeared after the stabilization sequence. Thank you in advance!
kanini
04-05-2008, 11:54 AM
Found a more comprehensive service manual now, that told me to clean the transfer belt, wich I did and the problem is gone now at least for the moment. But the P-5 error still remains, so I'll guess I'll have to clean the AIDC sensors anyway, since I can't get the stabilizer to work nor the gradiation adjustments.
kanini
04-05-2008, 03:18 PM
After cleaning the AIDC sensors (wich were clogged totally with toner dust) the machine is like new. Thank you anyway nmfaxman for your reply! And thanks to everyone at the forum, since it was from here I got the bits that lead to the solution! Happy copying!:D
snowdog
05-21-2008, 02:42 PM
Where did you find the ATDC sensor.
B0265
05-22-2008, 06:34 AM
For C/M/Y it's mounted on the LED Unit, in front side (for BK it's in the IU).
jethro tull
02-13-2009, 04:50 PM
Hi everyone.
Where can i find service manual for my cf 3102?
adastra100
04-14-2011, 03:35 AM
I have almost the same problem.
It seems like the background was covered with tiny spots of cyan evenly all over the sheet. I ran the stabilizer, and did a gradation adjust, and that is better.
Now, every dark cyan image leaves a ghost image about 3 inches away on every sheet.
I have tried different paper thicknesses, and lightness settings, but nothing seems to work.
I have tried 2 different transfer belts, and it doesn't make a difference.
Any ideas?
I am reaching the end of the rope.....
RRodgers
04-14-2011, 02:59 PM
Hi everyone.
You can buy it from manuals4you.
minimerlin
04-14-2011, 10:30 PM
Cyan IU!
michel
05-10-2011, 12:29 PM
THIS (http://michelsplace.co.uk/minolta-cf3102.html) might be helpful.
Zesti
05-10-2011, 12:44 PM
Your Cyan IU cleaning system is not working properly i.e the cleaning blade. Let me know if further help is required.
