View Full Version : C451 Fuzzy horizontal lines on whole document
stryder
05-21-2014, 07:21 PM
Hi guys, wonder if anyone has ran into this problem before and what you did to solve this problem. This c451 is printing out documents that has rows and columns of 4 thick black fuzzy horizontal lines on the whole page. Any input would be appreciated, updating the firmware, changing drum, developer, belt, fuser did not work.
copier tech
05-21-2014, 08:17 PM
Can you post a sample?
stryder
05-21-2014, 08:22 PM
here is a picture of it. 25093
copier tech
05-21-2014, 08:36 PM
Interesting, does it do the same in colour?
stryder
05-21-2014, 08:40 PM
Yes, every printed document, color, bw, print and copy
minimerlin
05-21-2014, 08:46 PM
MFP Board?
copier tech
05-21-2014, 08:50 PM
Looks like a PH fault, have you got any P-codes?
jotunn
You've got damaged memories on mainboard (PWB-MFP). It could be also damaged SO-DIMM memories, but it's much less possible than PWB-MFP fault.
stryder
05-21-2014, 08:56 PM
So possibly a bad MFP, will have to try that then. thanks
mikeena
05-21-2014, 09:10 PM
Thin lines or linear strips may appear on copies/prints.
Solution
CAUSE: SDRAM failure on MFP board.
Note : Attached is a sample of the output when the SDRAM fails. To viewthe PDF, you may need to download a free copy of Adobe Reader®.
SOLUTION: The SDRAM has been replaced on modified (new) MFP boards. Affected boards can be replaced FOC through warranty replacement. Please
follow normal FOC procedures for replacement as outlined below. The following part numbers are available for this program.
bizhub C353 (p/n A02E H341 06)
bizhub C203/C253 (p/n A02E H342 06)
bizhub C650 (p/n A00J H021 00)
bizhub C451/C550 (p/n A00J H020 07)
The affected board must be sent back for warranty credit.
SSD REPLACEMENT PART(S) CLAIM ORDERING PROCEDURE :
Part(s) can be ordered via the online SSD Solutions RA/Claim form which is accessible in MyKonicaMinolta.com ? Service ? Warranty, Repair & Special
Programs ? Warranty Services & Technical/FOC Programs ? SSD Technical Solutions Claims ? SSD Solutions RA/Claims form.
Select the appropriate Solution ID from the “SSD Solutions” pop-up box in the SSD Solutions RA/Claim Form. The choice will then display a description of the
associated part that will be shipped. Under this SSD program, KMBS will ship Replacement MFP Board at LDN Pricing. The returned MFP board must be
accompanied with a print sample exhibiting the MFP issue. Upon receipt of the defective MFP Board at the KMBS Warranty Recovery Center and verification
of the SDRAM issue, KMBS will issue a credit to reverse the MFP Board Warranty Advance Exchange charge.
All parts will be shipped via UPS 2-day Air Service, and an automated E-mail will be sent to the submitting KMBS Customer confirming the shipment. In
addition the E-mail will provide KMBS claim number, part(s) order status and the UPS Tracking Number for the delivery.
SPECIAL NOTE : Solution contribution by Bill Ehmke, ESS
Solution
