View Full Version : BIZHUB PRO 1051
Hi
jam at registration section in bizhub pro 1051 ;j-1712 .any idea
RRodgers
05-23-2014, 05:27 PM
Remove jam. :)
mikeena
05-23-2014, 11:05 PM
Hi
if it is a constant my guess would be clutch/ motor
Saghir377
05-25-2014, 05:49 PM
Dear you didn't mention complete details any how in 1050 paper jam at registration normally low wait if it is low wait paper try to adjust loop from programming
if it is in thick paper then check clutch but mostly its from registration loop.
hope this will work.
Downunder
05-27-2014, 08:11 AM
Make sure the long paper dust (on metal remove-able plate) collector on registration unit is pushed all the way home.
Also to test if the double feed prevention sensor is working, turn it off with dip sw 26-2 = 1 disabled.
If this stops your 1712 jams then your sensors are either dirty or faulty. If you replace them make sure you replace them as a pair.
The copier will work ok with it disabled. depends on your clients requirements etc. good Luck.
Rolandito
05-29-2014, 05:15 PM
Clean Paper trays clutches...
Sometimes the paper is not feed at a good speed making a jam in registration unit.
