View Full Version : Error Code C0096
ToeyCleary
05-29-2014, 11:23 AM
Hi
I have 2 machines showing this fault, with a clicking noise, just before the error code shows.
It appears to be that the transfer belt is so stiff that the solenoid is jumping. Any ideas would be welcome
stevena86
05-29-2014, 01:04 PM
Before Blackcat can come, I'll go ahead and take this one.
What model? :D
minimerlin
05-29-2014, 07:58 PM
I will take a stab in the dark that it is a Bizhub C35! Remove the transfer belt and take off the 4 springs holding the yellow and magenta 1st transfer roller units. You are correct the springs are too strong and the drives cannot shift the slide unit..take them off machine works!
ToeyCleary
05-30-2014, 11:54 AM
Thanks, yes C35 is correct. I will try as you suggest and report back, sounds good though
giddyupngo
10-31-2014, 10:36 PM
Hi, I took off the four springs mentioned, and machine worked, but did not print yellow, since the belt was no longer touching the yellow drum after the springs were removed. I am leaning more towards the answer on this thread, but I have not investigated yet.
http://www.copytechnet.com/forums/konica-minolta/84194-c35-c0096-fault-code-1st-image-transferpressure-retraction-error.html?highlight=C35p+c0096
EarthKmTech
11-01-2014, 01:07 AM
had a lot of these errors now, we simply write the machine off and replace it when this error occurs now and cant be reset.
