Synaux
05-30-2014, 02:07 AM
First let me just shoot out there that I am well aware of most if not all of the IU fixes/mods/issues discussed on numerous older threads. That being said, I feel inadequate having to post this, but still hopeful.
There are 3 machines with the same general behavior ONLY on black:
< - - - - - - -25180
This scan is not great and a little washed out, but this halftone print (from Service Mode) is perfect on the dark end; however, it exponentially lightens towards the back on the machines/prints.
HV contacts cleaned, PH cleaned, switched around tranf rollers/belts and fusers. Played musical chairs with the IUs and even manually replenishing toner.
Ran/reran Reset/Stabilize & Gradation.
Then I messed around with TCR 3, DMax +10 and ran 250 sheets with almost no coverage and reduced the fade by about 50% on one machine.
I then installed a new IU that immediately exhibited the same results on the two machines I have tried it in so far.
At that point it was time to go home.
Table Numbers:
VDC-K:
399 Machine #1
333 Machine #2
410 Machine #3
VG-K
~490 Machine #1
~450 Machine #2
~500 Machine #3
Level History = Good
IDC Output = Good
All machines in a decent environment with ESP protectors (2 machines are at the same location and the other elsewhere).
Thats about everything my scrambled brain can recall right now.
Thanks in advance!
Table Numbers:
VDC-K:
399 Machine #1
333 Machine #2
410 Machine #3
VG-K
~490 Machine #1
~450 Machine #2
~500 Machine #3
IDC Output = Good
Thanks in advance!
