Bizhub C203 Waste Toner Pipe cleaning?
  • leoace
    • Jan 2012
    • 12
    [Misc] Bizhub C203 Waste Toner Pipe cleaning?
    Hey guys,
    i have technical trouble with a bizhub c203. The first technican replaced transfer belt, fuser and IU without success. I throught the harsh noise of defective gears came from the main drive unit, but after replacing this one the machine now keeps telling us "insert waste toner box" after a few rotations - still with the terrible noise.
    I know that the c220/c280 series got that problem with blocked waste toner pipes and i guess its the same problem here.
    My question - is there a better way to replace or clean the waste toner pipe as removing the whole back/pcb cage/drive unit ect.???
    thanks
  • rrrohan
    • Sep 2011
    • 1977
    I had one about 6 months ago. Pretty full on to strip it down sadly. I attempted VAC out port but when toner hardens even a good VAC won't be enough
    Sounds like the previous tech needs to brush up on diagnostic skills if they tried a fuser unit
    • leoace
      • Jan 2012
      • 12
      Re: Bizhub C203 Waste Toner Pipe cleaning?
      Yeah i guess its too late for a simple cleaning with duster/compressed air or similar if the gears dont move anymore and the machine stops completly... sigh ... fine, will stip the bitch again then. I thought it might be possible to reach the pipe from the front without too much trouble.
      My coworker told me there was no noise (?wtf?) at his visit so these parts have been ordered and replaced on spec
      • hotfuser
        • 180
        This is a pain in the backside. If you take the horizontal casing off so you expose the toners, remove the toners you will see which one is blocked.
        Try forcing a stiff wire down the chute too unblock and vac out. This hopefully will save a strip down.
        Have fun
        • ck1
          • 485
          Have fun
          Good idea... i will try it . thanks
          • ivovb
            • 695
            Have such a problem. After several disassembling, cleaning and changing gears I have 2 garbage and 4 days wasted... Good luck anyway.
            BR
            I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
            • stevena86
              • Oct 2012
              • 130
              This is why we replace these machines when this happens. It seems almost impossible to completely resolve the issue once it arises. Good luck to you.
              • Synaux
                • Mar 2012
                • 1224
                Perhaps this is why all users should install a dehumidifier and use only OEM toner?
                • fishleg
                  • Mar 2009
                  • 425
                  The blockage will be in one of the toner hoppers not the waste toner. Best way is hoover hoppers out completely then use air compressor to blast the blockage out from the top. If left ages tho it destroys the gears that connect main drive to the toner drive and those are impossible to change >
                  • ivovb
                    • 695
                    I am using OEM toner! Concerning dehumidifier, well this is good point.
                    BR
                    • zalim
                      • Mar 2012
                      • 44
                      i am not very good with this model but check your toner PIPE, it might be damaged or broken...
                      • Hansoon
                        • Sep 2007
                        • 3350
                        Good Lord......
                        Hans
                        “ Sent from my Intel 80286 using MS-DOS 2.0
                        https://www.copytechnet.com/images/smilies/biggrin.png
                        • hotfuser
                          • 180
                          BR
                          It does happen with OEM toner as well as compatable. The problem occurs due to the toner solidifying in the chutes this is because the toner chute is near the rear of the fuser.
                          the exhaust fan doest not cool it down so the toner in the pipe gets hot and hardens causing the blockage.
                          i must have removed 15-20 machines with this problems.
                          have fun.
                          • ivovb
                            • 695
                            have fun.
                            Nice. Not happy with this info. Thanks anyway. Any workaround, because I would not like to remove more c203...
                            BR
                            • stevena86
                              • Oct 2012
                              • 130
                              Work around? I guess you could somehow retro fit an external waste toner system that bypasses the broken internal one? Haha, no.. No workaround really.
