Minolta CF2001 Error C13CC . Any Resets on this
C13CC New Oil Coating Unit
resetting failure
The output from the new unit detecting terminal
remains HIGH and the copier does not recognize
that a new unit has been installed.
1. The fuse blowout signal of the new unit is set to a
blowout state.
2. After the lapse of 0.5 sec. after step 1, the fuse
blowout signal is brought to a state where no
new units are installed.
3. After the lapse of 0.1 sec. after step 2, a new unit
check sequence is carried out.
A total of two cycles of steps 1 to 3 are carried out
and, if the copier fails to detect a new unit a second
time, a malfunction condition results.
try trouble reset (butten is inside pin hole behind front door under image unit removing handel.
if it comes back you might have blown the board
