John Kaufmann
07-01-2014, 05:13 AM
I happened to find a Fiery IC-412 (previously on a C452) on eBay and was fortunate to get it at a price within budget - but when it arrived I learned that the installation is different for a C280. I asked the seller if he knew anything about the different mounting brackets, but received no reply, so I made mounting brackets from some aluminum angle. However, the C360/C280 instructions (unlike the C652/C552/C452 instructions) show a 2-piece "gasket" (p/n A0YEIXC075DA) to be attached on each side of the cable connector for the VI-505 interface card (AKA "relay circuit board"). From the instructions:
13. Remove the paper backing from the furnished
gaskets and attach them to the left and right
sides of the relay circuit board connector.
Note:
Make sure that the relay circuit board connector
and the gaskets are in contact with each other
when installing the gaskets.
Can someone tell me what this gasket is [from the instructions, it looks like foam tape], what is its purpose, and why it is needed for the C360/C280 but not the C652/C552/C452? Do you know where such parts are sold?
Also, the cable connecting the IC-412 to the VI-505 has two thumbscrews on each connector which use a VERY fine thread (M1?) - unlike any other connector thumbscrews I have seen, especially for a such a big connector. One of the screws has a broken thread. Do you know where to find these screws?
Note:
