View Full Version : c550 c650 Toner compatibility with OCE
Synaux
07-02-2014, 06:56 PM
Just curious if anyone tried any of the OCE CM4521, CM5520 and/or CM6520 in a c451 c550 or c650 (excluding mix-matching the 451 model black toners with the higher models due to incompatibility).
Are the chips the same, but do the cartridges have a tab that needs to be broken off like with the old 8031s??
chegen
07-02-2014, 09:31 PM
BIZHUB C 451
WorldWide
Develop
INEO + 451
EU
Imagistics-Pitney Bowes
CM 4521
WorldWide
Oce
CS 231
WorldWide
Olivetti Lexikon
D-COLOR MF 450
EU
BIZHUB C 550
WorldWide
Develop
INEO + 550
EU
CM 5520
WorldWide
Olivetti Lexikon
D-COLOR MF 550
EU
BIZHUB C 650
WorldWide
Develop
INEO + 650
EU
CM 6520
Toner and developer are same on all, i don't have information about every chip, but from what i see in this table i think are the same.
Synaux
07-02-2014, 10:10 PM
Thanks for the info
I was 99.9% sure the toner was the same. One of my suppliers is trying to dump some surplus OCE stuff on me at a bargain.
I really need to know if the chips are the same.
Even if the cartridges are physically different, I have screw drivers, duct tape, funnels and even a Dremel if necessary.
copierwhisper
07-03-2014, 12:44 AM
We had one Oce' in the field for a while and we used Konica Minolta toner with an Oce' chip. No tabs to break off...
Synaux
07-03-2014, 08:51 PM
So...being that you guys were using a Oce chip, can I assume that you were forced to change the chip?
Synaux
09-25-2014, 02:49 AM
I just wanted to take a second and update this.
The toners are the same if you swap the head of the toner unit (front plastic part--3 screws)
As I suspected you must use a Konica chip (even from an empty cartridge).
If you use a chip from an empty cartridge, the machine will still run; however, it will always report that the cartridge is almost empty.
