View Full Version : Error Code SC101, MPC305spf
Marvin Rivas
07-02-2014, 10:15 PM
Good day everybody, I have a Ricoh MPC305spf with a SC101, iīve change BCU, IPU, Controller, power supply, even scanner unit from a death machine with flat and regular cables, updated firmware, and nothing, i donīt know what else do......:confused:.
If anyone had a idea?
Thank you......
ruben
07-02-2014, 11:21 PM
Restart the machine with the scanner lid open. Does the lamp move to the white plate position? If not, replace the scan motor. Else, does the lamp stay turned off or flicker? If so, replace the lamp and/or stabaliser. Else, does the lamp stay on for several seconds and not return to home? If so, replace the IPU and/or lens block. In all cases, clean the white reference.
Ronan
07-10-2014, 08:53 PM
Tried cleaning the rule you have in the beginning of the scanner, which is dirty and sometimes it fails to start reading. regards
