View Full Version : minolta pro 1083 code c0520
mkopoiuy
04-10-2008, 05:50 PM
anyone can help.
i have error code c0520 with minolta pro 1083.
how can i reset this code.
please help me.
mkopoiuy
Hansoon
04-10-2008, 08:19 PM
C0520 means Fuser overheating. You have to reset the machine first by hitting a tiny reset switch on the main board. When you know where the switch is located you can reach him from the front if the machine is swung open but the first time I'll think you need to remove the upper back cover for orientation. The switch is located at the lower right corner of the main PWB-A.
Good luck!
Hansoon
mkopoiuy
04-10-2008, 11:37 PM
thank you Hansoon!!!
i can do now.
mkopoiuy
Joe3of12
03-14-2011, 08:45 PM
I cannot seem to find the board with the reset button on it. Can someone please elaborate a little further on how to gain access to the board, with the reset switch? thank you
minimerlin
03-14-2011, 09:04 PM
Open the clamshell, look at the back of the machine , the main board is behind the upper rear cover. The switch is clearly shown in one of Hansoons pictures in the post from 2008. I suggest that you clean the fuser thermistor or most likely the code will come back! If you are not a Tech be very careful what you touch at the back of the machine!!
Joe3of12
03-15-2011, 09:53 PM
I have the same code on a Minolta CF 2002 does anyone know what that code means on this machine?
minimerlin
03-15-2011, 10:29 PM
I have the same code on a Minolta CF 2002 does anyone know what that code means on this machine?Same thing..fuser temp incorrect!
Did you find the reset button for your 1083?
