View Full Version : Miscellaneous Bizhub C280 Wont Copy or print NO ERROR CODE ???????
QUALITY IMAGING
07-10-2014, 07:09 PM
C280 Wont copy or print, not reports or anything. It all goes into the Que and says Stop Print. Formatted the Hard Drive. Same problem. No error codes. Get Blue start light and the red light on side. Please Help.:confused:
emujo
07-10-2014, 07:23 PM
One or more of your consumables has reached it's life end. Either replace the needed items, or install the PPLM mod as this will allow the MFP to run past the stops. Emujo
QUALITY IMAGING
07-10-2014, 07:28 PM
I checked the consumables and nothing is maxed out. Could something still be at lifes end?
CompyTech
07-10-2014, 07:35 PM
Had a similar problem if an LCT is attached. Open the LCT tray, remove the paper, check for folded paper, reinstall - should work ok. Usually a few bent and folded sheets of paper at the bottom of the stack borks the whole machine out for some reason.
emujo
07-10-2014, 07:42 PM
If you are getting the stop print message, something has reached it's end. Look at the life counters in service mode...IU's Xfer belt, 2nd x-fer roller, fuser, filters wont generate the stop print. Emujo
kingarthur
07-11-2014, 03:37 PM
go into the enhanced security mode & set the print stop to "NO STOP", if you are a dealer, there is a bulletin on the infohub
