View Full Version : C1070 static problem
faultman
07-11-2014, 07:20 PM
Has anyone experienced a massive static problem on the C1070. When copies exit the machine everything appears fine but as the prints stack on top of each other they become stuck together with static. Happens on all types of stock and paper weights. Machine is brand new.
KM1Amsterdam
07-11-2014, 09:02 PM
I noticed that thin paper curls around the fusing belt, never though it would be a static problem.
Blizzoo
07-12-2014, 11:48 AM
Just my 2 cents,change the power outlet,make sure that you have the right voltage
tulintron
07-14-2014, 01:41 PM
Check if the power grid is grounded and the accessory is with Brooms grounding paper
eg101
07-14-2014, 03:15 PM
Tape a piece of Bounce in the exit area
methogod
07-16-2014, 09:16 AM
what kind of paper?
what are the paper specs?
what do you have the press set to (paper catalog)?
Michael Peters
07-27-2014, 02:37 PM
Hi. I have exactly the same situation on a new C1070 - although uncoated paper is less affected. Also the machine gives electrostatic shocks all the time! Have you managed to resolve your issues - if so, how?
Michael
blackcat4866
07-27-2014, 02:49 PM
I would make sure that the anti-static brushes are all properly grounded in the finisher. Perhaps I might try to add a few more anti-static brushes. =^..^=
methogod
07-28-2014, 08:45 AM
Make sure your setting your paper correct. What type of paper and what weight.
We run all day and night and only have major static when we fold in our bindery...
Good Luck...
MFPTech
07-28-2014, 02:57 PM
What are the accessories for your machine? Is it using the dehumidifier?
Michael Peters
07-28-2014, 03:21 PM
I have a standard set up:
Bizhub C1070 Engine Only
Suction Fed Paper Drawers
Relay Unit
High Cap Stacker
EFI Fiery (Embedded)
we use mainly digital coated paper, that has given no issue on our other digital presses (past or present)
Tech Helpdesk
07-10-2015, 01:10 PM
The static will be eliminated with the fitment of the new RU517 this is supplied by K-M FOC.
