View Full Version : C2S Paper using bizhub C250 or bizhub C352
goldencup
07-12-2014, 06:40 AM
Hi, i would like to ask if is it okay to use C2S Paper on bizhub C250 or bizhub C352? If it is, what thickness # of the paper can be use and what setting is needed to adjust on the machine (example: fusing temp adjustment). Also, what is the maximum thickness of paper that can be use on the machine? Thank you very much.
emujo
07-12-2014, 02:00 PM
Can't find a spec for 2CS, but the C352 runs A3-B5, and A5S, 80 GSM and below from trays or bypass, 91 GSM through 256 GSM bypass tray only, there are no thick settings for the trays. You should not have to modify any settings as long as you choose the correct thickness settings and use the bypass tray. Emujo
