methogod
07-14-2014, 06:26 AM
My dumb ass decided that the new Command Workstation needed to be installed on my RIP. I always test the new CWS on my desktops and it worked great.
So installed on IC-305 whihc is running XPe 32 bit, 3.0a - which ill get back to.
The 5.6 version did not install correctly and just ruin the install. I think it didnt finish install the extended applications, and because of unknown reason there was no fixing it. Tried to manually uninstall and re-install and got no where. I was able to make it thought the week using a desktop version of CMW just not on the local RIP.
Over the weekend i tried to install Windows 7, and manually installed System 9, and Extended applications 4.1 which took great. 4.1 is one step back from 5.6 i tink its 5.5 something it works ok.
Go it all tweaked and working, just couldnt find a driver that would install the EFI Serial Card. The driver was there for XP, but wouldn't "turn on" then i even tried to pull it from the Ic-306 which is newer that didn't work. SO back to the drawing board.
If anyone has this figured out it will make your rip so much faster. it looked and worked great. Just without the Serial card its just a expensive grey box.
