View Full Version : C353
jonpaul
07-14-2014, 11:58 AM
We have a biz c353 first it got stuck in warm up,so left it over weekend,came back it now says it has paper jam which is does nt,help.
tulintron
07-14-2014, 01:16 PM
damaged sensor, firmware update.
Issac-brock
02-19-2015, 12:30 AM
:confused:
Any update on this? I just ran into a warming up machine after replacing the print head to solve a C4551 code. Code gone but warming up forever.
Thanks,
Colin
allan
02-19-2015, 05:24 AM
reseat it again.
laitang
02-19-2015, 08:02 AM
What's the jam code?
Issac-brock
02-19-2015, 12:29 PM
reseat it again.
Will try it, also may do firmware, HDD etc.
Blizzoo
02-19-2015, 01:59 PM
:confused:
Thanks,
Colin
Check the interface cable comming from scanner to mfp for bent pins/poor connectivity
habik
02-19-2015, 02:41 PM
:confused:
Thanks,
Colin
Have you adjusted the lasers registration? Stabilisation etc.
I had one 253 that was freezing up..usually over the weekend... no C-codes , just send a print job machine dead...reboot worked fine. This was happening more frequent eventually coming with laser error.
Changed laser problem gone.
What about the RAM's have you tried changing it?
Issac-brock
02-24-2015, 01:18 AM
Solved.
One of the new lasers was defective. After swapping the black and yellow lasers it would intermittently display a yellow laser fault code or say warming up forever. Replaced the yellow with an old unit I saved just in case.
Works fine now.
