View Full Version : konica c10 blank streaks
DOE
07-15-2014, 06:27 PM
have a konica c10 that has 1/16 inch blank streaks across page in same place whether its a black and white or a color copy. could it be the laser unit? thanks
tulintron
07-15-2014, 07:56 PM
I had the same problem in C8000. In my case it was toner. Cleaning the toner supply system. Load new toner.
in your case, the mark repeats after a certain time in the same place, or randomly?
Hansoon
07-16-2014, 06:31 AM
Clean the glass of the laser window. Remove the drumunit and look into the cavity you will see a glass strip around 100 x 10mm which need to be cleaned. Silly construction BTW........
Hans
