View Full Version : Error Code c-3508 error
Dfriis
07-24-2014, 09:27 PM
Had paper jam and it snap a code we reset and now as soon as you turn it on you see the transfer rollers gap and turn then it snaps c3508 error. It will do it ever time you cycle the power,
Any thoughts
Don
Dfriis
07-24-2014, 09:29 PM
I guess I should say km 6500
CopyJunkie
07-24-2014, 09:44 PM
A C3508 will occur after you had four continuous J3102 Jams.
You need to go into the service mode and set DIPsw 3-1 back to 0 to reset the service code.
Dfriis
07-24-2014, 11:09 PM
We have done the switch
but the problem is when the paper get to the fuser rollers they tight down so tight that it stop them from turning.
Any one ever seen this??
Joseph.ARM
07-28-2014, 03:53 PM
I'm running into the same problem.
I've tested the motor and it seems fine. Output codes 47 (0-2) were okay, but it had an issue with number 3 (Reverse rotation: pressure release operation On, normal rotation).
Any ideas? I appreciate the help.
kopydoc
07-28-2014, 05:29 PM
Gentlemen,
your problem is the one way bearings located on the front side of the fusing unit are slipping replace them there are four one is located on the lower roller of the belt assembly the other three are in the pressure drive assembly make sure you scotch brite or sand the shafts before putting the new ones on and make sure you put them on the right way ive seen techs put them on backwards and it take out a few gears so be careful good luck oh and you may also want to replace the torque limiter on the the bottom side of the fuser in the back it also slips
Joseph.ARM
07-28-2014, 05:47 PM
Thank you. Do you happen to know the part numbers of the one way bearings? Its difficult to tell the difference between the normal bearings and one ways in the service manual.
kopydoc
07-28-2014, 06:30 PM
The one way gear that goes on the lower fuser roller of the belt assembly is(A03U809500 x1) the other three are (A03U809311 x3)
i attached docs hope this helps
2582225823
Joseph.ARM
07-28-2014, 06:52 PM
Helps a lot. Thank you kopydoc!
