seniortech
07-30-2014, 07:43 PM
I have a failed system board (OACB) on a C6500. This board comes with no firmware installed so you cannot flash the machine using a USB drive so I have to use the ISW TRNS tool to download the firmware to the board.
Normally you would plug the laptop into the printer port on the R/H rear side of a good working machine machine using a printer cable and the C6500 USB driver to use the ISW tool would then download and install on the laptop. This worked fine on my old laptop running windiows XP. I now have a new laptop running windows 7, when plugging in the printer cable an unspecified device is now available in device manager but no USB driver is installed. I tried downloading the USB driver from a working machine in preperation of changing the board on the defective machine so at the moment I cannot use theISW tool to flash my new OACB. The customer is now getting a little jumpy as their machine is down.
Try as I may I cannot get the KM C6500 USB driver to install on my laptop. I can only assume the one that is downloaded off the machine is not compatable with windows 7.
Anyone any ideas on how I can get this to work?
