View Full Version : how to reset fuser code konica 350 black and white copier
can a konica tech tell me how you reset fuser codes on konica 350. i have looked on internet and got 5 different solutions and none of them are right. thanks for dev codes just fix and turn side switch off and on. must not be same for fuser codes
Hi. I don't know this Konica but, on Konica C451, you reset fuser changing a fuse on fuser unit.
blackcat4866
07-31-2014, 08:30 PM
I'm a little unclear on something. Are you getting a "Replace Fuser Unit." maintenance message, or a "C3901" error message. There's a big difference. =^..^=
Flash
07-31-2014, 10:56 PM
On the right side of the machine near the top there is a little cover where the ethernet and usb port are. To the left of those ports there is a reset switch. Press it. When you see a dot on the touch screen press the number 3 and enter 00000000 for service entry. Press trouble reset.
Iowatech
08-01-2014, 12:29 AM
blackcat4866 (http://www.copytechnet.com/forums/members/blackcat4866.html) is right, if this was just a preventive maintenance alert you will probably be OK, but if there is a service error code you would be better served if you found out what the actual problem is and fix that first.
(Heh, for one thing, when high temperature plastic parts melt they create an awful odor, at least the ones on the early 3M 516AGs did.)
MontanaUniversityProf
05-26-2018, 04:51 AM
Thanks for the hint I bought some of these fuses and it reset the page count as you suggested. I'm posting the link so that people know where to look for them and what they look like:
4 Konica Minolta Fuser Unit Fuse Reset Fuses Bizhub Color Copiers (https://www.kopy-kat.com/4fuseFuserBiz.html)
