tervel12
08-04-2014, 02:05 PM
Hello,
I have a customer that has an AS/400 system and when they print to their bizhub 601, it will not switch trays when the tray runs empty. The device is created as per KMBS recommendations (see below) and all trays are configured the same. Any ideas how to get this to work?
It switches trays fine when printing from a Windows PC and the tray runs empty.
KMBS device creation:
To Create a Device Description on AS/400(R) to print to KMBS printers perform the following:
1. From the Main Menu under Selection or Command, type: CRTDEVPRT <enter>.
2. Change the following to set up the printer (those settings not changed, keep at default):
a. Device Description - (name the printer i.e., KMPrinter)
b. Device Class - *LAN
c. Device Type - 3812
d. Device Model - 1
e. LAN Attach - *IP
f. Port number 9100
g. Font Identifier - 011
h. Form Feed - * Autocut
i. Manufacturer - *HP5si
j. Paper Source (both) - *letter
k. Address - (TCP/IP address of the NIC)
l. User Define Option - *IBMSHRCNN
m. System Driver (hit F4) - *IBMSNMPDRV or *HPPJLDRV if SNMP is disabled in the environment.
Note: Vary ON the device to allow attachment.
Thanks for any input.
d. Device Model - 1
e. LAN Attach - *IP
f. Port number 9100
