I am an IT Manager at a University and have had a problem for a few months with some of our BizHubs that are inconsistent with scanning to PC's.
We are on XP Pro. We setup a folder called 'scanner': C:\scanner. We share it and Allow Network users to change files.
We allow MS File and Printer Sharing.
We enable Netbios over TCP/IP.
In PageScope, we create accounts under Fax/Scan. We choose the Com. Mode as TX:PC(SMB). We specify each machine by IP address. The file path is 'scanner'. We enter the username of the administrator account on the machines and put in the password. Coding method is left at MH.
Windows Firewall is enabled on all our machines.
Problem is, we can set this up on one machine, and it scans great. The next machine, with the same computing environment will not receive scans unless we completely disable the firewall, which is not an acceptable solution.
Out copier techs have no answers. Any information would be very helpful.
