Turn off the machine. Press 47 and turn on the machine, don't remove your fingers pressing the numbers. press 90 and press print to clear the PM counter and 91 to clear the drum counter. In my experience when i reset this counters sometimes the P26 code will appear. it means need to calibrate developer but sometimes even you calibrate it the P26 is not resetting until you replace the DV. Sometimes i only increase the PM count to remove the maintenance indicator. To set the PM count off the machine press 25 P32-37 just increase the numbers and P39-44 for the drum. Adjusting exposure 36 P90.
