View Full Version : Electrical Konica minota bizhub 751
Nhimbob
08-18-2014, 11:02 AM
Hi..
Please help me
I have bizhub 751 only copy by bypass, tray 1,2,3,4 and ADF can not be used currently
Zackuth
08-18-2014, 02:12 PM
First check and make sure the trays and ADF haven't been turned off in the service mode.
Albonline
08-18-2014, 08:47 PM
there is a one way clutch behind the bypass unit that has taken a crap.
Nhimbob
09-19-2014, 10:13 AM
Hi...
Thank you for your answer, ask you one more question this machines only copy 150 sheets how to fix it.
Thank you very much
copier addict
09-19-2014, 05:24 PM
Hi...
Thank you very much
I think we may need a bit more detail.
Nhimbob
09-20-2014, 02:42 AM
Ok, That mean when I copy 500 sheet the machine only copy 150 sheet and stop, I must touch continue on panel to copy.
Downunder
09-28-2014, 11:18 AM
Hi..
Please help me
Does the paper get fed from the cassettes, and if so where does the paper stop. If it stops in the vertical unit it could be that the drum pawl solonoid wires have been shorted out on the bearing on the main shaft. Remove drum unit and check at rear of drum unit. If it has shorted you will need to replace print control board. (ICP blown)
