View Full Version : BizHub 223, no data lights?
copyman
08-18-2014, 02:47 PM
Prints config page with correct IP. No data lights
when ethernet cable plugged in. Cable is tested and
live. Does printing config page confirm controller
is good?
Any type of reset, firmware or something else I
could try?
Thanks for the help
fuzzyg
08-18-2014, 02:53 PM
is good?
could try?
Thanks for the help
We had a similar issue and it was the main brd that was faulty.
We also tried firmware and all sorts but no getting around it unfortunately.
copyman
08-19-2014, 03:25 AM
Turns out the router was bad. Now have lights at port on copier but still won't ping. I tried a few different IP's didn't help. Any ideas ?
Thanks again
wseyller
08-19-2014, 04:20 AM
Are the network settings configured properly for the new router? I would recommend going to the network settings on the copier and set to auto obtain. Let it pull a new IP address, gateway, dns, from the new router. Most routers will have its own dhcp server and the copier can obtain all the network settings automatically. This copier it will make you turn off main power off then back on. Give it time to pull a new IP. Look and see what the new IP address of the copier is and try to ping it. If good then set the copier to manual in the TCP/IP settings and change the IP to what you want (change to unused IP in the same subnet range) and ping again to confirm it is still OK.
Could be the new router is on a different subnet range which happens a lot when changing router as the default config differs between routers.
