skibum
08-25-2014, 04:13 AM
I have a CS300ix ready for delivery and can't set the ip settings static or dhcp to show a ready or enabled condition on a status page. The setting does go in but then when in the window that shows network settings IPv4 setting is 0.0.0.0 and when you print a status page it says IP Address Not Defined (see attachment) In the setting window for the static ip the ip shows my setting correctly. The machine has had restarts, firmware upgrade and even a new main control pcb assembly with no change.
I tried to ping from a laptop using a crossover cable but still no success. I am able to ping a FS1135 in our shop ok but not the CS300ix. The setting are not holding and showing up other than last entry in the window to ad a static ip. Strange??? Any ideas would really be helpful. I need to deliver this asap.
Thank you!!
Thank you!!
