If it is a 7320 or 7370 you need to cheat the cabinet switch on the left side of the machine to get the display to light then install the
DV drawer the execute test command C O O C 25 then the CSK(paper selection) then the PRINT switch. It should stir for approx. 3 min. then it will display a number between 01 and 99 which should be the toner level.
