View Full Version : c5501
mike cooper
09-04-2014, 01:52 AM
will not warm up any help
Mick01
09-04-2014, 02:19 AM
Hi,
Are your fusing lamps turning on?
Have you checked continuity of the lamps?
Have you checked continuity of the Thermostats?
Have you checked the connectors between the fusing unit and main body?
Is your machine showing any SC codes?
mike cooper
09-04-2014, 12:24 PM
Hi,
This machine is new to me only had it 2 weeks worked fine 1 week then will not warm up
it shows no codes
Mick01
09-05-2014, 12:47 AM
Hi,
If you are an end user I suggest you get a trained technician in to help you resolve this issue.
Most likely will be a fault in the Fusing Unit or AC driver board. The list I gave you previously is what a technician will check to try and isolate the fault.
