minolta CF 3102
  • shezi
    minolta CF 3102
    hi all,
    i want to attache a machine minolta cf 3102 with LAN OR LPT
    but its not working IP adress are ok but machine,s printing is off from printe controler card (Fairy) so any one how help me to open webtools
    how to open webtools to make changes or there is any other way to change settings.
    waiting your reply
    thanks
  • suso73os
    • 38
    Hi, you can see the actual ip in the fiery panel, the put the ip in your browser and also you migth disable any restrictions alow access to some activex to be able to see the web tools.
    • doma873
      • 24
      When you configure the fiery remember to turn on port 9100.. This is common problem as it is turned off by defalt..
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        With IP printing, you need to make sure the port name is changed to Direct or Print, too.
        • bowser
          • 25
          printing
          Originally posted by shezi
          hi all,
          waiting your reply
          thanks
          1. print configuration from fiery and make sure ip has taken (menu,print pages,config)
          2. ping ip address make sure u have connection
          3.yes check driver port for 9100 or configure port (print Que "print",enable bite count)
          4. print test page
          webtools check version of java use sunjava.com,check popupblocker and check explorer for page refresh. really need more on what type of problem for webtools
