Has anyone found a way to set the default mailbox to anything but !default. On the scan to file screen if you click to edit an smb mailbox there is a choice to set as the default mailbox but it never works on this machine.
Set default mailbox KIP 7970
In case anyone needs to know the "set as default mailbox" button is broken and does not work. As a workaround you first select the mailbox you want as default. Then in the preset you select save. Don't type anything in the text field. At the bottom select "use as default". Confirm yes to overwrite the file.
