ClarkIR
09-11-2014, 10:17 PM
I have a current customer who was using a 3232e, and utilizing the scan to pc option in conjunction with Scanner File Utility. They are upgrading to a 300ci. however we have run into a snag. They use an FTP server that utilizes ports 21 & 22. for newer equipment as I understood it you had to use FTP setup with port 21 to use the scanner file utility. so i cant use that port for the FTP, and other ports I tried did not work
I didnt know if anyone had a resolution for this that would allow us to continue to use the scanner file utility. This server has 30-40 folders on it, and I didnt want to commit a guy to all that time setting each individual folder up on SMB sharing. (im still not 100% sure I can use SMB with their current security as it is set up, a previous tech attempted and failed to get it to work during the initial install)
so... any tips?
so... any tips?
