View Full Version : KONICAMINOLTA BIZ-600/750
herath176
09-12-2014, 01:59 PM
Few minutes After power " on " the machine, the massage, " warming up , ready to scan " appears but " ready to copy" massage not displayed , Pls inform me the solution.( fuser lamp off )
Kidaver
09-12-2014, 02:10 PM
Clean your Toner Control Sensor Board, attempt Maximum Density Adjustment, if that doesn't work replace the TCSB, and try Maximum Density Adjustment again. If that doesn't work you are probably looking at replacing a Printer Control Board.
Edit: I just noticed you said the fuser lamp was off...I'd check the continuity of the lamps also...but from my experience and what I've seen on here it's likely the TCSB or Printer control board.
