View Full Version : bizhub C224 error C-6102
backspace
09-12-2014, 11:15 PM
Hi,
i have code 6102 on bizhub C224 (Scanner). I try FW, clean, reconnect, test lamp, test home sensor, trouble reset, initialization - clear error. And problem still persist.
How i can test scenner motor?
I am also tech.
TNX
laitang
09-13-2014, 12:40 AM
...How i can test scenner motor? I am also tech....
Why not replace and try?
- scanner motor
- scanner drive board
- printer control board?
blackcat4866
09-13-2014, 01:28 AM
Hi,
I am also tech.
TNX
I've heard that some techs read manuals, and sometimes find the information all by themselves. =^..^=
copier addict
09-13-2014, 01:53 AM
I'm sure that is one of those urban legends, cat.
blackcat4866
09-13-2014, 02:09 AM
I suppose its a lot easier to get some dumbass to look it up for you on a forum. =^..^=
backspace
09-13-2014, 10:06 PM
Thanx anyway....
toner cartridge
09-18-2014, 03:35 AM
Hi,
I am also tech.
TNX
it is problem MFP board, try to check.
Toner Chip Supplier (http://www.einmay.com)
emujo
09-18-2014, 01:25 PM
Unfortunately, the ability to test motors and solenoids has been omitted on most of the newer K products. But as a test, you can try turning the MFP on and watch for the scanner (scenner) to move. If it moves to the home position, and the lamp lights you can probably rule out the motor and lamp (capt obvious!!!). If it has the dual scan (701) you may want to look at 2nd side board, and ribbon cable. Also ensure you have the right DF selected in service mode. Emujo
EarthKmTech
09-19-2014, 06:19 AM
I seem to recall hearing about this from a tech recently. There is a bulletin about this, but I'm afraid I CBF looking for it sorry.
occus
09-19-2014, 03:37 PM
In my case it was the PCRB... and not the scanner board! (PRCB are the last position to fix the error on the bulletin)
backspace
09-30-2014, 07:53 PM
I slove this it is problem with:
1. scanner motor
2. scanner drive board
I had to replace both parts.
TNX
