BIZHUB 754E C-1141
  • jujitsu47
    COPIER TECH SPECIALIST
    • Jun 2014
    • 20
    [Jamming] BIZHUB 754E C-1141
    C-1141 Intermintently jams, any ideas would be appreciated....
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: BIZHUB 754E C-1141
    And you've done what so far ?
    And what finisher is installed ?
    • laitang
      • Nov 2012
      • 627
      • jujitsu47
        • Jun 2014
        • 20
        FS-534 and not much, its daily and often but not every copy? ck'd sensors and motor in service mode
        • habik
          • 2013
          Re- # sensors NOT in service mode!
          I had one which was OK in Service mode I/O check and day later it wasn't OK in I/O check..
          so sensor out and meter out!
          Firmwares HERE
          • giddyupngo
            • Oct 2014
            • 109
            BIZHUB 364e with FS-534
            Hi, just wanted to mention I had this code today, after taking apart the FS-534 finisher, there was excess white grease on the timing wheel, which got into the PS14. Replaced sensor and tested OK. However strangely enough in Service mode the state of PS14 didn't change from 0 to 1. However running the paddle motor in Service mode worked.
            PS14.pdf
            • bronco31
              • Aug 2009
              • 174
              Re: BIZHUB 364e with FS-534
              [ATTACH]34117[/ATTACH]
              i cant find the Load Check in the BH808 Service manual for running M5, the paddle motor.. in the FS=536 finisher?
