Failing to recover C3508 ever after replacing fusing unit and resetting the error,i replaced the PRCB of a working machine to see if there is a PRCB malfunction but to my bad luck bothe the machines are stuck with CC 101 Error due to mismatch firmware in the PRCB's. is it possible to restore the machines by uploading new firmwire?
C6501 Error CC101
Re: C6501 Error CC101
Looking at the SM it doesn't state anything about firmware mismatch.
It says :
When the sub power switch
(SW2) is ON, no response is
received from the printer control
board (PRCB) within the specified
time.
So check carefully all wires and connectors, If they are all good check ICP23 on PRCB. Replace if needed.
(If unable to locate ICP23 (2.3A fusable link), it can be found in the lower left section of the PRCB near connector CN301)
Good luck. -
It says :
time.
Good luck.Comment
i have replaced the fuse and it is all set . THANQ SIR YOU HAVE SAVED ME.Comment
