View Full Version : Konica Minolta BizHub Press C7000
rgalban
09-19-2014, 09:42 PM
I have a Konica Minolta BizHub Press c7000 that powers up goes through the "please wait loading" screen then when it goes to the Konica Minolta screen the machine is basically frozen from that point. Can anybody let me know whats causing this to happen and how I can fix this problem?https://mail.google.com/mail/u/0/?ui=2&ik=48d9071147&view=fimg&th=1488f98ff755f552&attid=0.1&disp=inline&safe=1&attbid=ANGjdJ-o_mftX2ou9AAOyfZ4axqk94GxDyu9pa9n0jnBoV4wa1TFrU8C9 k4HvI-EjlOns5FoRs2Bz919ACndTmt1NwyqkHPWTd2g1b-v6NWahhWMomfPgicBhOYo0rQ&ats=1411158471395&rm=1488f98ff755f552&zw&sz=w1896-h869
gurko_gg
09-21-2014, 10:07 PM
Hello
did you try reload firmware with isw?
rgalban
09-22-2014, 09:11 PM
No I haven't, but it wont even let me into service mode
kalindd
09-23-2014, 07:47 AM
If the problem is with the firmware try the so called recovery mode?
Get firmware G00-40
create folders C7000\I\I0\ in the usb drive
then copy in the last folder A1DU021_00I0_G00_4000.BIN
then rename it to recover.bin
Start the machine, the power save LED should blink orange and display should say "Please wait starting system"
Connect the usb memory to usb port.
Green LED means: reading file from usb/ deleting flash
Blinks in green means: writing
When the LED starts blinking in green you can disconnect the usb.
Machine will restart automatically if everything was successful.
I've done it in the past and it worked out well form me.
You can check it in service manual page J - 3.2 Boot USB memory ISW.
Good luck and let us know if it was successful.
