View Full Version : MP-C2500 SC 533
ABS tect
09-23-2014, 03:17 PM
What is the SC 553 code for the MP C2500?
laitang
09-23-2014, 03:59 PM
SC 533 code: check toner supply tube fan in the rear of machine
26535
ABS tect
09-23-2014, 10:32 PM
[QUOTE=laitang;437653]SC 533 code: check toner supply tube fan in the rear of machine
Thank you so much for the response, I apologize, I actually meant to write SC code 553
slimslob
09-24-2014, 01:27 AM
Same as for other Ricoh equipment. Heat roller overheat error. Could be thermostat, thermistor, lamp, PSU, IOB or a loose connection. Repair the problem and then reset the fusing error.
