habik
09-26-2014, 02:02 PM
Hi There
Have a customer running on OSX 10.9.4 and have a problem printing a specific document from Excel (2008) it is giving Error Offending Command Limit Check / Sending command - shfill Stack.
I have had this issue with Windows before but never on Mac. My solution was to use PCL driver on Windows machine.
On this machine I have guided customer to change emulation from KPDL (Auto) (with Alternative Emulation PCL6)) to just PCL 6 and it printed a lot of gibberish pages.
Driver version 8.4 is used on OSX 10.9.4 and it is a standard setup KPDL with Finisher option
Can print any other documents no problem just this one is giving headache. Funny enough the same doc can be printer on OSX 10.7.5 from Excell 2011
Tried Re- installing printer driver and also tried using Generic Post script driver all the same.
Tried Exporting to PDF and when pdf printed same result. Command shfill stack error.
Excel document is containing some sort of background (image) ? and is essential in the document!
Many thank you for any kind of advise..
I hardly get stuck for words over telephone with customer, this issue stroke me to the ground level.
