View Full Version : Dead Machine Copystar CS 2030 C710 Error,(Toner sensor problem)
Doug James
09-30-2014, 05:47 PM
Went to a working machine and cleaned the drum corona wire. The machine worked for awhile and then started throwing C710. I then changed the developer (Ran U130) the machine worked for a few days then the C710 error cam back. Question; Is the toner sensor glued in or is their a way to get it out. That is my next area to investigate. Not sure the Toner sensor is available though. Any feedback is greatly appreciated.
quitech
10-01-2014, 12:01 AM
4 me i do use u131 to control this problem use your brain
Doug James
10-01-2014, 12:51 AM
4 me i do use u131 to control this problem use your brain I actually did set U131 at 125 from 154. Thought I tried higher numbers but will do tomorrow... Thanks for your feedback
