Laserbeam
10-14-2014, 05:01 PM
Now it is the third time, that I write here this thread, but now everything is displayed correctly.
@ Zackhut: Thousand thanks for your help !!!
Good Morning, :rolleyes:
i have a problem with a bizhub 601. Only by double-side the paper often jammed at the drum (going under the drum-claws). The first side separated perfect, but the 2nd side is going too late away from the drum.
I replaced the transver/Separation corona with a new one, but without success. In the tech-menu I increased the value from Separation (AC) Manual adjust or tried several times to change the value from Separation (DC) Manual adjust, also, unfortunately without success.
Also new dry paper brought no success. Although it took an improvement but the problem still exists.
