BH-C-353 color registration off...
  • Hansoon
    • Sep 2007
    • 3350
    Machine has 150K, CMY IU's 50%, K IU 80%, TB 50%. CM needs correction up to +4 in X direction, Y is at maximum +6 in X direction but is still not enough and would need ideally another two steps.
    This customer is very picky and using a fat magnifier to check the color registration pattern. What do you guys suggest to correct CM to become more near to a middle value and especially Y to become exact?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • Hansoon
    • Sep 2007
    • 3350
    Re: BH-C-353 color registration off...
    *cough*
    Hans
    • paulrid
      • Nov 2011
      • 206
      Note sure if this will help but can you check PH are in tolerance. Go to service mode then state conformation, colour regist and check step value CMY is within spec +-4, if not perform manual adjustment.
      Paul.
      • allan
        RTFM!!
        • 5459
        Are all the lines on you manual registration page all parallel?
        Whatever
        • mo0651
          • 1054
          Are those re-chipped Iu's??/
          • Hansoon
            • Sep 2007
            • 3350
            Hard to believe that IU's are causing this. Must be something with TB and/or the IDC/registration sensors I feel.
            Hans
            • habik
              • 2013
              We do a lot of short term rental with these machines and I guarantee you that moving this series from A to B will put laser registration out! PaulRid gave you the right answer to your problem. Takes 10 seconds to check in system 1, state confirmation,color registration and as said above just adjust each color laser to the spec. Mine spec with clients like you have is +-1.
              I open tray 1 half way, remove front door hinge pins and with flat blade (8mm wide for easy turning, doesn't slip out from screwhead) just adjust according to step position! + clockwise - counterclockwise! Listen carefully for CLICKS! Each click= 1 step.
              If numbers don't change there is likelihood your step gear is out of position on laser unit or laser unit it self is not sitting properly in place usually secured by stainless bracket! Pain to get lasers in or out if you are in hurry. All toners and IUs and TB out, left cover & top tray & front cover & fuser cable cover & cover to the right (white) comes off. Check now if gears for CMY are meshing.
              Other than that...faulty Laser Head unit.(unlikely)
              Sent from my iDon't believe in marketing device using Tapatalk
              Firmwares HERE
              • habik
                • 2013
                Forgot to add when you adjust the laser shut the door
                Firmwares HERE
