View Full Version : Paper Jam at Fusing Unit Entrance Minolta Di3010
Maindron1
10-15-2014, 11:16 PM
Hi,
I keep having the same paper jam at the fusing unit entrance, If I clean it a bit, It will print one or two pages and then start jamming all over again, I have ordered both upper and lower fuser rollers but I would like some feedback to see if the problem might be somewhere else.
Any help would be greatly appreciated.
Thank you.
Mike copydoc
10-15-2014, 11:54 PM
Make sure you replace the bearings in the fuser when you replace the upper and lower rollers. Also, since it jams when entering the fuser make sure the registration clutch and all the brass bushings throughout the transfer unit are clean and properly lubed.
Hansoon
10-16-2014, 06:11 AM
I only once had that the guide rail mounted at the entrance (underside) of the fuser was deformed causing the jams.
Hans
allan
10-16-2014, 09:42 AM
Jip probably the bushings on the registration. Had that a couple of times.
fixthecopier
10-16-2014, 02:03 PM
I would replace the reg clutch after ensuring it has the same jam from all trays. Usually if the reg is slipping you can see the image track off the page. Run F-12 test prints to check image location.
copier addict
10-17-2014, 06:12 PM
Also, unclip the registration housing and blow out the registration sensor. It gets dusty and causes intermittent jamming in this area.
