View Full Version : error code c-6104 bizhub c224e
hi, I have already change the sensor PS7, motor and the board for the df 701 , any others suggestions.
Thanck you
kingarthur
10-16-2014, 04:51 PM
There was a bulletin about replacing one of the RADF cables
Thank you for the reply, to day I replace a complete fede df 701 same problem. I change also the memory same problem.
Bulletin witch number
EarthKmTech
10-17-2014, 12:22 PM
If the second side brush is stalling in the gain adjustment position and the paper stops dead in its tracks and then throws the code, replace the mfp board.
(after you have replaced the black second side CIS cable first as these ALWAYS fail, you have already done this by changing adf, so go ahead with board and let me know)
thank you, I am ordering the mfp board under warranty. I let you know. Have a good week end.
Hi, we replace the machine. But now I am working on the problem at the showroom. so, i am ordering the mfp board. Thank you
B0265
06-08-2016, 03:53 PM
Did a new mfp board solve this?
