View Full Version : C350 Default Settings
MinoltaMan
04-23-2008, 06:12 PM
How do I make the default color for copies black? The machine is set to a color default.
minolta35
04-23-2008, 07:41 PM
This is admin setting.You can choose it admin mode.
MinoltaMan
04-23-2008, 07:49 PM
Im having problems accesing the admin mode
minolta35
04-23-2008, 08:31 PM
This is not a problem a minoltaman!:cool:
Learn it your admin...:D
Frostwolf
04-24-2008, 02:46 AM
Not sure where in admin mode you do it, but here is how I do it.
Set the screen setting you want IE "black mode" "auto paper" whatever they want
hit utility key
then store (if memory serves)
then current settings and ok
Panel reset should set Black and white now.
first you have to choose black on the normal copy screen. then go into the user mode under utilities and somewhere in there, there is a current settings/ factory settings. press factory setting then current setting. it shoud stick.
ni311
05-10-2008, 02:45 PM
You have to options:
1. You can set the default auto color level. If you move the cursor to far left, all the copies will be b/w
2. as cmb said above, you can change anything and then save the changes in current settings. After an reset/restart all the current settings saved above will be the default settings.
