View Full Version : Ocè Imaging Units in Konica Minolta
groovy
10-23-2014, 01:45 PM
Hi all,
anyone here knows if a brand new Ocè Imaging Unit can be fitted "as-is" in a konica minolta copier?
I have various C353, my distributor sells me one IU for € 326,00 + 22% tax + shipment
Found a user that is asking € 160 for 2 imaging units new boxed, so it is a big saving!!
That imaging units are branded Ocè but the product code is IU313, so i know for sure that fits into a C353, my only doubt is for the chip.
Thanks.
Blizzoo
10-23-2014, 02:01 PM
If Oce imaging unit fits 100% you can swap chip from old KM IU and instal PPLM Fw then after ready to go.
groovy
10-23-2014, 02:05 PM
Or i'm thinking to put in a thirdy-part reset chip.
copier addict
10-23-2014, 02:08 PM
Definitely use a new chip. It will ensure the IU is set up properly. Then install the PPLM firmware.
Blizzoo
10-23-2014, 02:09 PM
Or set IU's to Non Stop but will notify replacement on mfp display.
groovy
10-23-2014, 04:12 PM
If Oce imaging unit fits 100%.
I must be sure that it fits correctly
habik
10-23-2014, 07:50 PM
Copier addict is right!!
Very wise advise.
New IU has a process of getting correct TCRatios and if you pull chip from used IU it will give incorrect TCR level readings from initial setup of the old IU on to the new IU. I hope this makes sense to you.
I tried to play smart once as we use three vendors and the only way to get things going was to use third party chip and then PPLM firmware.
Sent from my iDon't believe in marketing device using Tapatalk
Blizzoo
10-24-2014, 06:57 AM
Very wise advise.
You are right.
groovy
10-24-2014, 10:00 AM
thanks to all.
BUT i must be sure that fits correctly, this is my first question.
groovy
11-10-2014, 06:01 PM
I'm replying to myself for all of us: Ocè Imaging Unit fits well on a Konica Minolta C353. Chip is also recognized.
Works as original ones.
