View Full Version : Ikon CPP550 (KM C5500) Side Paper deck sensor problem?
Georgerc
11-02-2014, 01:33 AM
Hello everyone,
The large capacity paper tray (Side deck) of my Ikon cpp 550 is not recognizing the paper inside in the middle of the run. Machine runs, then stops, asking to fill the paper. When I open the cover and close, it runs for a while and stops.
Is there anything wrong with the sensor? What should be done?
George
methogod
11-03-2014, 09:34 AM
which paper deck? the single tray or double?
try a can of air left and right of the feed roller...
the sensor may be dirty with paper dust...or the sensor is failing.
clean, if that doesn't fix, then swap sensors there are 2 that are the same part number, one tells it to lift the other tells it when its completely empty.
By switching you should see the issue change if it doesn't, but the sensors back - and it something else.
I would also check the connector between the main body and the PAPER DECK or LCT. if its not in all the way, that could be your issue.
But intermittent issue is usually clutches and sensors.
