Good evening all after long time contacting you. I have one machine LD6500 konicaminolta it shows error C-C101 in detail this code came when an icp is open from printer controller board. i check and replace it but machine makes only 5 prints and msg. came (right side cover open) with in second it changes (ready to print) then again (right side cover open) it happens around 10 to 12 time then machine stop when i restart machine again shows C-C101 same icp open again any body have information about this problem.
I check wiring maybe some wire short with body but i did not found even i replace the board but same story happen kindly help me.
Thanks & Regards
Thanks & Regards
