View Full Version : help for MINOLTA cf1501
Nassim
04-26-2008, 01:40 AM
Hello!
I have minolta cf1501...when i turn it on every think is ok...but it show all the time "Booting system.." ..then show "wait".... then " Booting system"...
what i must to do...?
and how can iinstall another time the server of the printer...
please help thinks....
ck1
04-26-2008, 03:43 AM
did you try reset the server ? this maybe is the ram or the hdd problem . try clear the server first
mitchl
04-26-2008, 03:09 PM
If it has a controller it sounds like someone ran the reformat option on the X3E:o, which as I recall gives you the perpetual boot screen........ if indeed the case reload system software or what EFI refers to as system code.
cobiray
04-26-2008, 08:22 PM
Powering the Fiery down improperly can cause the unit to fail giving you this message also. At best, the OS needs reloaded. Possibly, and in my opinion more than likely, the hard drive will need replaced for it to be operational.
rsxrob
05-07-2008, 05:01 AM
i have seen this many times this fiery is very flaky and has a tendancy for the system software to fail. if turned off and on quickly it will fail. you nedd to reload system software. one other thing it could be is a corrupt file sent to it which means you have to try and clear server.
JB271
05-07-2008, 01:12 PM
Oil supply roller changed per message.
Now see code C13CB.
How do I over-ride and/or reactivate unit to run again?
thanx, JB:confused:
JB271
05-07-2008, 01:25 PM
Now see code C13CB.
thanx, JB:confused:
cobiray
05-07-2008, 11:43 PM
Open and close the front panel to reset the error code. The code is for the oil unit you just replaced. Take the unit out and make sure it's installed properly. Also check for any visible damage to the unit.
lucky13
05-09-2008, 03:38 AM
check the reset fuse in oil supply unit it should be 1/2 amp or lower
ni311
05-09-2008, 08:11 AM
also, check to see if it is burned or not. Sometimes, the fuses are badly calibrated, if this is the case, try with a new one.
