View Full Version : CF5001 (bizhub C500) fiery problem
smart-refill
11-09-2014, 10:03 AM
hello
I have a problem with my CF5001. When I plug in network cable into the fiery's RJ45, the "controller" icon from the screen disappear and the printer mode (fiery) is disable.
After this plugin I can use my CF5001 only in copy-mode. I must turn off the copier to enable the printer mode (fiery).
I changed my network switch, I used a crossover cable direct from my computer but without changes.
In this moment I print only with the parallel port.
Do you know this problem? any solutions?
Thank you!
habik
11-09-2014, 05:16 PM
I'd start with firmware c500 and software fiery update.
Have you tried Cat5e cable with only 4 pins live (1,2,3 and 6) and simplex only?
Sent from my iDon't believe in marketing device using Tapatalk
iust
11-09-2014, 07:49 PM
what do you use for your network ? (CAT5 or CAt6). please check the network speed when everything is OK and set the fiery speed setting. (100 or 1000 Mgb/s).
if it is OK . come back to firmware offer
smart-refill
11-09-2014, 08:49 PM
@ habik (http://www.copytechnet.com/forums/members/habik.html)
I don't have a firmware for C500 or a fiery's software.
I will try to use a Cat5e cable with only 4 wires tomorrow.
thank you
@ iust
For my network I use CAT5 and the fiery speed is set to 100Mb/s.
thank you
RRodgers
11-10-2014, 04:52 AM
Try a different cable, are you using the internal or external Fiery?
smart-refill
11-10-2014, 05:02 AM
I try with three or four cables and two network switches - same rezults.
I use a internal Fiery.
Thank you!
RRodgers
11-10-2014, 05:29 AM
"Might" have to reinstall the OS.
smart-refill
01-24-2015, 04:29 AM
I solve this problem changing the fiery. I buy a external fiery and now I can use the network port.
Thanks all!
