View Full Version : Miscellaneous Konica Minolta C652 Drum, Transfer Belt and Fuser Reset
mearmi
11-12-2014, 12:35 AM
Hi
How to reset Konica Minolta C652 Drum, Transfer Belt and Fuser Unit?
Thanks and Regards,
Mearmi
Foxhound
11-12-2014, 06:38 AM
(2) New Release
• After replacing a fusing unit or transfer belt unit, perform New Release to clear its life
counter.
1.
Select the key as follows.
[Counter]
→ [Life] → [New Release].
2.
Select a unit where New Release is made.
3.
Press the Start key and perform New Release
From Service manual I hope this helps
habik
11-12-2014, 06:40 AM
T160mA fuse can be bought at Katun, and its easy to find them on ITB and Fuser.
Sent from my iDon't believe in marketing device using Tapatalk
copier tech
11-12-2014, 10:23 AM
The C652 doesn't use a fuse system, the reset procudure was correctly posted above.
It the c451 series that uses a fuse.
habik
11-12-2014, 01:06 PM
Nr tripping on vendor models! Ta
